So I’m in the process of replacing master cylinder and brake fluid reservoir as it’s badly cracked and I can’t seem to find a brake fluid reservoir anywhere... does anyone know where to get one from or an alternative that I can use? I’ve got the carb engined gt2 1.8..
Brake fluid reservoir
Moderator:Scirocco Register
- fill in the right answer:15
- fill in the right answer:10
Re: Brake fluid reservoir
If i am right this is the one you need.
Check the partnumber with yours..
https://www.google.com/search?sxsrf=ACY ... CAs&uact=5
Thanks Blueshark that’s exactly the one I was after but no one has them in stock or available... I may just have to do the servo upgrade and mc and get a mk2 gti 16v reservoir... if they are easy to find lol
I think item 303279484403 on ebay maybe what you need - looks very similar
2011 VW Caddy Van C20 Startline 1.6 TDI 102PS 65k
2015 Skoda Yeti SE Outdoor 1.2 TSI DSG 105PS 35k
2013 Fiat 500 Pop 1.2 69PS 40k
2009 VW Fox 1.2 54PS 60k
2009 Smart Fortwo Passion 1.0 mhd 71PS 25k
