Hi guys,
Just picked up some BBS RA wheels for my rocco!
anyone know where i can get some locking wheelnuts so they dont get robbed!? the chap ibought them from mentiond Mc Guard??
Ed
BBS Wheelnuts...
Moderator:Scirocco Register
- fill in the right answer:10
Re: BBS Wheelnuts...
mcgard ftw! every now and then i have to remove locking nuts/bolts when the car owner has lost the spacial tool. i can confirm that mcgards are very hard to remove!
probably these that you're after http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0514360946
just make sure you keep a note of the key number somewhere in case you loose it! ;)
probably worth shopping around a bit. i reckon you should get them for under £20
They're both radius seat rather than cone seat.McGard Website wrote:Thread Size OEM Hex Size
M12 x 1.5 bolt 17mm
Wheel Locks/Nut Style - contains 4 locks and one key Part No. Photo
Original Equipment Steel Wheels 28176 (78)
Original Equipment Alloy Wheels 28175
Original Equipment Steel Wheels 28175 (78)
Sorry, there are no installation kits available for this vehicle.
Footnotes
(78) 88-09 steel wheels use 28175. 81-87 steel wheels use 28176.
THREAD SIZE - M12 x 1.5
KEY HEX SIZE - 17mm
STEM LENGTH - 28175 = 23.300mm
STEM LENGTH - 28176 = 20.600mm
Yes, you need radius head (I think the ones Nate posted are tapered, which is only for after-market stuff on VWs).
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 592wt_1141
yes radius seat it is, i had a look at the studs that came with the wheels! nice one!
thanks chaps!
I'll get some got!
Ed
thanks chaps!
I'll get some got!
Ed
