7.5 inch rims
Moderator:Scirocco Register
thebrief_1979
fill in the right answer:10
7.5 inch rims
Post by thebrief_1979 » Tue Nov 23, 2010 10:12 pm
Hi guys, any advice appreciated on this topic
i have a standard mk2 gt2 scirocco 1993 and its on 15 inch bbs ra's
possibly looking to put different wheels on it - thinking of 7.5 wide rims - if i put 195 wide tyres on it will they go under the arches without rolling them
cheers
1993 MK2 Flash Red GT2 - sold
Mk1 gls - nearly
Re: 7.5 inch rims
Post by GTXTRA » Wed Nov 24, 2010 10:49 pm
you'll need 45 series rubber - ronal ls a good fit at that 7.5 x 15 size.
:good:
thebrief_1979
Re: 7.5 inch rims
Post by thebrief_1979 » Fri Jun 17, 2011 11:43 am
will i get away with 185/50/15 on a set of Ronal LS's - if not what size (195/45/15?) would you reccomend without rolling the arches
failing that how much are my 15" bbs RA's in very good condition with part worn (5mm) firestones 185/50/15 worth?
tring to work out the best value solution
thanks
Mk1 gls - nearly
benlg81
Re: 7.5 inch rims
Post by benlg81 » Fri Jun 17, 2011 7:49 pm
im running 15x7.5 et 23
1955015
lowered 40mm and no issues at all even loaded up
Col
Re: 7.5 inch rims
Post by Col » Fri Jun 17, 2011 7:56 pm
i've used 16x7.5j et25 rims before. 205, not sure on profile. they where too wide offset. on standard suspension, any load inn the back caused rubbing. 15's with lower profile / thinner tyres could be a different kettle of fish though.
ive still got those wheels, probably going to sell them on after a refurb.
