9x16" Borbet A - possible?
Moderator:Scirocco Register
DeeJayDready
fill in the right answer:10
Post by DeeJayDready » Fri Jul 23, 2010 12:13 am
Hi guys,
I’m currently running my Scirocco GTII on 7x15 Borbet A rims all round. The front wheels have a small metal spacer between the wheel and the brake plates.
I am looking to switch to 7.5x16” on the front and 9x16” on the rear, as seen here: http://www.potn.co.uk/borbet--a-crystal ... 024348.htm
The car currently sits on -40mm springs.
Is anyone else running a similar setup? Can this be done without problems? Any advise on this?
jimmyconway
Re: 9x16" Borbet A - possible?
Post by jimmyconway » Sat Jul 24, 2010 10:05 pm
It's gonna be a good summer.
Johnny_E
Post by Johnny_E » Sat Jul 24, 2010 10:26 pm
I think the image on that link above says it all Danny!
:swoon:
Post by Mr Funk » Mon Jul 26, 2010 9:23 pm
Been really tempted to change the T's for A's. I run 9s on the rear and 7s on the front. No brake issues but it needed arch work
ash-lough
Post by ash-lough » Mon Jul 26, 2010 9:44 pm
I'm not sure about the 16#s, but if you do go for it what might be happening to the 15's?
Ash
b5byt
Post by b5byt » Mon Jul 26, 2010 10:15 pm
I'm not a fan of Borbet A's, but 9x16 is more than possible, a little bit of clever arch work and you should be good to go :good:
1984 Scirocco Storm Cosmos Blue < Body has really had it, if you need parts off it let me know < Going.
1986 Scirocco Scala (Rocco-Jocco's old one) Having some life put back in to it
2001 Carbon Black E39 M5
2008 Carbon Black E60 M5
DeeJayDready
Post by DeeJayDready » Mon Jul 26, 2010 11:31 pm
Cheers for the comments guys.
I see two of you have refered to 'arch work'. Would this me a minor modification of sorts or a full arch transplant for the rear? If it is the later, i may have to abandon this for now. Finances would not permit such an extravagant mod, with other things still to be sorted (speakers, gauges etc). If I can do this at the cost of the wheels, then recoupe some of that cost by selling the current rims (with new tyres just fitted) then i will. So I suppose the question is, how much of this 'arch work' would be required to fit the 4 new wheels?
Ash, the 7x15" wheels would be sold.
Post by Mr Funk » Tue Jul 27, 2010 7:21 am
The arch work isn't a massive job and there's a few good Bodyshops/garages that'll do it for about £50 a corner. I know that The Phirm have done loads of cars on here and my own local garage does it but I'm in Kent so that may not be practical.
The front is quite easy as all it needs is the poo shields removing, everything cleaning and sealing. Don't muck about with the sealant either, make sure yo get a good coat of it everywhere otherwise you'll get problems later.
The rears are a bit different though. Standard issue is to cut the metal lip, heat the plastic body kit and fold it back on itself then seal everything. It keeps everything firm and stop the kit flapping about.
I've got 16's and it's pretty low. You'd expect the ride to be a bit harsh but it's absolutely fine
ash-lough
Post by ash-lough » Tue Jul 27, 2010 4:42 pm
Do you have a buyer for them yet? If not what sort of price would you be after?
Ash
DeeJayDready
Post by DeeJayDready » Thu Aug 05, 2010 4:59 pm
Cheers Mr Funk.
At first I thought said operation would be a bit hairy and high risk, but a few other people have said that it is fairly standard fare. I think I will consult with one of the local vw specialists with a view to doing it and go from there.
Ash - I would probably be looking about £300 for the four wheels (including new fitted tyres). Obviously I was initially thinking of selling within Northern Ireland to avoid inevitably postage, but if someone else was interested that would be no problem.
ash-lough
Post by ash-lough » Thu Aug 05, 2010 5:29 pm
Hmm, I would definitely be interested if you did come to sell them at that price. Do you have any idea what sort of price delivery would be?
I never saw the Belfast bit be fore I must admit!
fill in the right answer:15
Post by ianaudia4 » Thu Aug 05, 2010 7:05 pm
Get in touch with Junglist, he has access to a courier service, I have used it quite a few times and it is spot on (and a good price).
Funky Diver
Post by Funky Diver » Fri Aug 27, 2010 11:00 pm
Monsuer Funk... What offsets are you running on those? The combination you're running is precisely where I wanna be, but don't fancy spending £800 on wheels to go and get the wrong offset :dunno:
