13x7 minilights alloys
Moderator:Scirocco Register
- fill in the right answer:10
these wheels are 4x100 pcd but with a offset of 7 i think will these be two small for a scirocco on coilovers and as anyone got a pic of one on these alloys
SCIROCCO GT
Member 934
Member 934
Re: 13x7 minilights alloys
think you'd have poke issues, odd handling too Lee, in addition to ground clearance issues?
could end up looking a bit like this motor on some 14's -
having said that i am about to acquire some alleycat more vw friendly offset, 6 x 13 Rims with 175/50's on to try on the Mk1 eventually. worth a shot i think.
My offset is 13, you should be OK. Also worth bearing in mind that your speedo may go out of whack tho bud. Would look rather nice on the other hand!
You sure they are 4x100 mate and not 4x98?
Alex
Alex
Most Mini's run a PCD of 101.4, you can fit them. When people fit VW alloys to Mini's they use wobble bolts.
I have a set of 13" minilights on my mini at the mo, if you fancy a drive out your more than welcome to try them on fella.
Here are two pics of the wheels on my wife's car.
They are Smoor Roadstar 13x7 with 175-45-13 tyres.
If you want I have more pics or info.
Greetings, Joost
Greetings, Joost
yes please more pics and info what the ride like with the 13inch alloys
chhers chaps might just take you up on that
SCIROCCO GT
Member 934
Member 934
