wheels
Moderator:Scirocco Register
philebean
wheels
Post by philebean » Fri Aug 14, 2009 9:27 pm
dose anyone now if mk3 escort wheels will fit on a mk2 scirocco thanks
fill in the right answer:10
Re: wheels
Post by GTXTRA » Fri Aug 14, 2009 9:45 pm
no idea- you'll need to check the pcd (bolt pattern) and offset. - see below lifted from our FAQ section on website.
http://sciroccoregisterforum.co.uk/faq/ ... -you-need/
marksg60
Re: wheels
Post by marksg60 » Sat Aug 15, 2009 1:05 pm
the escort wheels will not fit any vw's as the ford stud pattern is 4x108. vw 4 stud is 4x100. scimilar offset tho ranging from et29-42 depending on wheel width.
philebean
Re: wheels
Post by philebean » Sun Oct 11, 2009 9:05 pm
ok thanks mate
gafr21
Re: wheels
Post by gafr21 » Mon Jan 11, 2010 9:19 pm
Escort Mk3/4 wheels definatly wount fit, different PCD. Think Toyota Rims of the same period may fit tho, as the same PCD.
Funky Diver
Re: wheels
Post by Funky Diver » Thu Jan 28, 2010 11:30 am
Fiat Punto wheels will also fit, with the appropriate spiggot rings :)
filmidget
Re: wheels
Post by filmidget » Thu Jan 28, 2010 1:32 pm
Aren't Fiat Punto rims 4x98?
They might fit, but they won't fit properly (without 'wobble bolts' or similar, another can of worms entirely).
Re: wheels
Post by Nate » Thu Jan 28, 2010 2:37 pm
yup, puntos (all fiats that i'm aware of) are 4x98 so will only go on with wobble bolts. wouldn't recommend wobble bolts to anyone though. dangerous as hell
Risocco
Re: wheels
Post by Risocco » Thu Jan 28, 2010 10:55 pm
Alfas are/were 4x98 as are Lancia. Must be an Italian thing......
Alex
Re: wheels
Post by Nate » Fri Jan 29, 2010 12:58 am
i think seats were too, before they became vag owned
