CABIN AIR EXTRACTION
Moderator:Scirocco Register
EDDIE-F
fill in the right answer:15
Post by EDDIE-F » Sat Oct 03, 2020 6:33 pm
In my Scirocco Mk2, there appears to be no means for air to be extracted out when moving. I remember on other older cars I have had. There was always a sneaky hidden air vent in the rear of the car to suck stale air out. some cars even made quite a thing of them with chrome grills or similar. Just always found my car to be stuffy. Anybody Know?
might have to fit one of those spinning things like on a BT van :-)
C 20 CCO
Re: CABIN AIR EXTRACTION
Post by C 20 CCO » Sat Oct 03, 2020 7:48 pm
I remember my 1995 polo 6N having the pressure vents just behind the rear bumper. I haven’t seen this type of vent on the 53B other than in the lower part of the doors, under the door pocket. There must be something in place to exhaust air, especially when using the heater controls. My 1991 scirocco smells just the same as my 1984 scirocco. Not a musty smell, but just the same odour from cloth and leather.
kind regards,
Dave.
To be old and wise......
GT_II
Post by GT_II » Sun Oct 04, 2020 12:37 am
Yes, the air exits through the grilles in the rear edge of the front doors, via the slot just below the door cards. From memory, there is a rubber flap hanging inside the door to let the air flow through the slot into the door and act as a non-return valve - maybe those flaps have been sealed up in an attempt to stop leaks.
2011 VW Caddy Van C20 Startline 1.6 TDI 102PS 60k
2015 Skoda Yeti SE Outdoor 1.2 TSI DSG 105PS 30k
2013 Fiat 500 Pop 1.2 69PS 40k
2009 VW Fox 1.2 54PS 60k
2009 Smart Fortwo Passion 1.0 mhd 71PS 25k
GT_II
Post by GT_II » Sun Oct 04, 2020 1:17 am
As shown here - with thanks to "evil len" on Pistonheads
fill in the right answer:10
Post by james butler » Mon Oct 05, 2020 7:31 pm
yes as gt_II says its very easy to cover these up in an attempt to seal up leaks
this is one of the reasons i fit my plastic membrane on the inside of the door
definitely worth checking
EDDIE-F
Post by EDDIE-F » Mon Oct 05, 2020 9:18 pm
Had a brief look at my door. Its clever how at a glance, you would never know there's a vent under there. when its not dark or raining , will have a good look. See if its as it should be. Thanks to all who replied .
C 20 CCO
Post by C 20 CCO » Tue Oct 06, 2020 9:20 am
If you need fit a new sheet of polythene use butyl sealer on a roll. It’s what I used when I couldn’t get the original sealer to cooperate. Use it around the openings to avoid water damage.
Look around for a good price and the size you want.
https://www.ebay.co.uk/itm/133466253653
kind regards,
Dave.
EDDIE-F
Post by EDDIE-F » Sat Nov 14, 2020 10:53 pm
Checked the flaps and vent in the doors. They were ok not blocked if anything a bit stuck open. However have recently sealed with silicone the under bonnet metal moulding. To stop fumes from engine bay via that, through to air vents. But most significantly adjusted my bonnet to pull down harder at the hinge end. this seems to have stopped the fumy smells coming in via the heater. by squeezing down better on the new plenum chamber/engine bay rubber strip. squirted a load of fabreaze aerosol into bonnet vents with the heater blasting. To freshen up the heater. Weirdly it seemed to lubricate the bearing as it now runs quieter. hopefully my stuffy interior might well be cured.
