Vacuum sensor connector, how do I fix this?
Moderator:Scirocco Register
p in phcas
fill in the right answer:10
Post by p in phcas » Tue Mar 16, 2021 10:40 am
The wire broke right at the connector. Any suggestions how to fix this or can the connector be disassembled and new connectors fitted?
GT_II
fill in the right answer:15
Re: Vacuum sensor connector, how do I fix this?
Post by GT_II » Tue Mar 16, 2021 12:06 pm
I think 037906240 will fit - perhaps others can confirm. The easiest option would probably be to buy one second hand with wiring tails attached - there are several on ebay.
2011 VW Caddy Van C20 Startline 1.6 TDI 102PS 60k
2015 Skoda Yeti SE Outdoor 1.2 TSI DSG 105PS 30k
2013 Fiat 500 Pop 1.2 69PS 40k
2009 VW Fox 1.2 54PS 60k
2009 Smart Fortwo Passion 1.0 mhd 71PS 25k
p in phcas
Post by p in phcas » Tue Mar 16, 2021 1:17 pm
Never messed about with one of those type of connectors. Is a special tool required?
p in phcas
Post by p in phcas » Tue Mar 16, 2021 1:47 pm
For anyone's interest - I found this really useful link on the VWVortex forum. Lots of useful VW specific electrical and connector references. https://www.vwvortex.com/threads/electr ... s.6948714/
GT_II
Post by GT_II » Tue Mar 16, 2021 2:03 pm
To fit new terminals into the connector you would need a non-insulated crimp tool suitable for the terminals used, something like this might do the job:
https://www.ebay.co.uk/itm/0-14-1-5mm2- ... SwLnBX6O69
Splicing a used connector with wiring tails still attached, for example by soldering and shrink wrapping the joint, would be an easier option, albeit not so elegant.
