Any idea what this component is?
Moderator:Scirocco Register
frlrubett
fill in the right answer:15
Post by frlrubett » Sat Feb 06, 2021 5:46 pm
Anyone know what this is?
Passenger side, in-front of battery. Under the front lip below bonnet. Does not seem to get any power on the multimeter and one of the clips have broken off.
https://ibb.co/8XczNQ8
https://ibb.co/DbLgHp5
fill in the right answer:10
Re: Any idea what this component is?
Post by mark1gls » Sat Feb 06, 2021 10:03 pm
I can’t quite see it in the picture but is it the size of a pack of polo mints?
If it is it should have the 2 yellow wires going to and it’s part of the side lights and not really needed, when you have the side lights (1st click on light switch) the little bulbs should be on and if the “polo mint” resistor is working the main bulb should also be dimly lit.
https://vwgolfmk1.org.uk/forum/index.ph ... t-resistor
Post by mark1gls » Sat Feb 06, 2021 10:11 pm
Here’s another picture.
https://www.ebay.co.uk/itm/VW-GOLF-JETT ... Swb55eJxnX
Forgot to say in last post... the ignition needs to be in position 2 (dash lights on) for the resistor to work.
frlrubett
Post by frlrubett » Sat Feb 06, 2021 10:43 pm
Yes thats it, doesn't seem to be getting any power, so might just cut the wires and tidy them into a chock box.
GT_II
Post by GT_II » Sat Feb 06, 2021 11:38 pm
Ah, not noticed that before, so that is for the dim-dip headlamps - a UK-only quirk of the late 80s and early 90s. Arguably still a useful feature for driving on well-lit roads at night, or as an alternative to daytime running lights, but no longer a legal requirement and not part of the MOT.
You should get 12V between one of the wires and earth, but only when the lighting switch is turned to the first stop (sidelights) and the ignition is switched on.
2011 VW Caddy Van C20 Startline 1.6 TDI 102PS 60k
2015 Skoda Yeti SE Outdoor 1.2 TSI DSG 105PS 30k
2013 Fiat 500 Pop 1.2 69PS 40k
2009 VW Fox 1.2 54PS 60k
2009 Smart Fortwo Passion 1.0 mhd 71PS 25k
frlrubett
Post by frlrubett » Sun Feb 07, 2021 8:39 am
Thanks will have a play.
