Air and Fuel Filters; GTX
Don't know German? look here
Moderator:Scirocco Register
GTXGTXGTX
fill in the right answer:15
Post by GTXGTXGTX » Sun Aug 25, 2013 11:21 pm
Does anyone know the part numbers for air and fuel filter for E Reg GTX please? Thanks.
fill in the right answer:10
Re: Air and Fuel Filters; GTX
Post by mark1gls » Sun Aug 25, 2013 11:33 pm
There is 2 types of fuel filter a thin one about 6cm in diameter and a fatter one about 10cm in diameter do you know what size is fitted to your car or even better measure it or a picture and I could tell from that.
Post by mark1gls » Sun Aug 25, 2013 11:38 pm
Picture of the fatter fuel filter... Also has MANN filter part number on it.
GTXGTXGTX
Post by GTXGTXGTX » Mon Aug 26, 2013 9:10 pm
Thanks for the replies. It looks like the Mann filter. Part number not visible on mine so thanks for the info.
Post by mark1gls » Mon Aug 26, 2013 9:25 pm
Also worth fitting new copper washers when changing the fuel filter, one side is the same size as the sump plug washer (need 2), you will get 1 of the other end with the filter but really need another 1 the same size. The fuel system is a high pressure so for the sake of a few pence worth changing them.
VW part number for the air filter 049133843. Eurocarparts and GSF seems to list them by size so might be worth measuring yours to check.
I fitted a K&N filter in mine as its a pain to get the air filter out and you don't need to replace a K&N every year!
Post by ianaudia4 » Mon Aug 26, 2013 10:23 pm
Later injection cars should have the larger fuel filter, still available from the dealers!
Jimmytdi
Post by Jimmytdi » Tue Aug 27, 2013 5:57 am
Im having trouble sourcing a fuel filter for my Gtx, its the smaller of the two but gsf and euros claim my car has the bigger one! The existing filter is a Kayser which I cant seem to find a cross match for (looks as if theryre no longer in business). I dread to think how long its been on the car!
'88 Jade Green GTX
Post by mark1gls » Tue Aug 27, 2013 2:11 pm
If you can post up a picture of what's fitted? From looking at your old posts you might have a larger type but its hard to see in the picture.
The smaller ones are available I'll get the part number next time I'm at my parents house as I fitted one to a mk2 storm last year.
Post by ianaudia4 » Tue Aug 27, 2013 3:46 pm
The smaller fuel filter (as fitted to my Storm) has the VW part number 431 133 511, no longer available from the dealers but VW Heritage sell them as do Crazy Quiffs. Mine was a Bosch filter so maybe your local Bosch retailer may be able to get hold of one for you.
The later type is still available from the dealers, part number 893 133 511.
Post by ianaudia4 » Tue Aug 27, 2013 4:45 pm
A quick look on Ebay found this!
http://www.ebay.co.uk/itm/Fuel-Filter-S ... 3f15ee2fc6
And a great link:
http://www.google.co.uk/url?sa=t&rct=j& ... wkjgD7Lu2w
This link shows all the comparable filters.
Post by mark1gls » Tue Aug 27, 2013 5:05 pm
I think it was the Mann WK618 filter that I fitted.
Jimmytdi
Post by Jimmytdi » Wed Aug 28, 2013 8:00 am
ianaudia4 wrote:A quick look on Ebay found this!
And a great link:
Thanks again Ian, youre the man for finding stuff on ebay! I never thought to look for mk1 golf bits (duh!)
'88 Jade Green GTX
