Rubber bump strips
Don't know German? look here
Moderator:Scirocco Register
harty
fill in the right answer:10
Rubber bump strips
Post by harty » Thu Aug 15, 2013 9:52 am
Morning Guys.
I'm looking for the part number for the rubber bump strip set on a Mk2 (front to rear)
Cheers Neil.
Blueshark
Re: Rubber bump strips
Post by Blueshark » Thu Aug 15, 2013 8:32 pm
With or without the bodykit?.
Joost
harty
Post by harty » Thu Aug 15, 2013 10:23 pm
Car is a 1989 GT with the black body kit.
With the plain black strip down the length of the car at waist height 5 sections to a side.
Cheers Neil
Post by GTXTRA » Thu Aug 15, 2013 10:33 pm
vw heritage is your friend.
most parts via classic parts - i've just placed an order for a complete gtx and a gtl set of trims.
harty
Post by harty » Fri Aug 16, 2013 10:08 am
I was told yesterday by vw heritage that only 2 sections for the right hand side of the car were available.
Do you have the part number for the set you have on order and are they the plain black type.
Cheers Neil.
harty
Post by harty » Wed Sep 11, 2013 12:29 pm
Still looking for this part number / numbers if anyone has them.
Post by GTXTRA » Wed Sep 11, 2013 8:19 pm
i'll get the numbers for you.
i've not received a full set - some doubles though - because of part number supercessions.
also - a couple of odd pieces appeared, slightly shorter pieces that i reckon suit the later non body kit GT AND and narrower strip that i've never seen on a uk market car.
harty
Post by harty » Wed Sep 11, 2013 10:11 pm
That would be great.
Cheers Neil
harty
Post by harty » Wed Nov 20, 2013 6:32 pm
Still require the part numbers chaps if you have them.
fill in the right answer:15
Post by ianaudia4 » Wed Nov 20, 2013 7:29 pm
Here is a link to the VAGCAT page, all the part numbers are there....http://www.vagcat.com/epc/cat/vw/COR/1989/13/56/186149/
harty
Post by harty » Thu Nov 21, 2013 8:21 pm
Nice one Ian.
Will get on to it now.
