No Spark
Moderator: Scirocco Register
si1856
No Spark
Post by si1856 » Mon Oct 21, 2019 6:55 pm
I was running the car ready for Mot and it just cut out. No spark. Tested the volts into the amplifier and ok. Nothing out though, no voltage spike. Bought a replacement off an internet site plugged it in, still nothing. Is there a fuse that could have gone. I’m thinking it could be a cheap unit that’s faulty? Thoughts - please help it’s booked in again this Friday
Nugg1985
Re: No Spark
Post by Nugg1985 » Mon Oct 21, 2019 7:03 pm
Could be just about anything, coil, distributer, leads, plugs. If you are getting power to the coil but nothing to the distributer there a few things to check
Sent from my SM-G965F using Tapatalk
si1856
Re: No Spark
Post by si1856 » Fri Oct 25, 2019 2:51 pm
All sorted. Required new coil as it had burnt out on the positive terminal frying the connectors and Amplifier. Starts on the button and it’s just passed the MOT - Woohoo!!!
Nugg1985
Re: No Spark
Post by Nugg1985 » Fri Oct 25, 2019 3:03 pm
Good to hear, glad you got it sorted
